Author Topic: <Playlist> results in Unknown Playlist for auto-playlist  (Read 1768 times)
ach
Using the <Playlist> field selector, for example when you want to use the converting tool, results in a "Unknown Playlist" for playlist that are auto playlist.
playlist is not supported in the file naming template. If its available as a naming field to select from then thats the bug
