I'm not sure it's still respecting the "least often played" setting? Play counts range all the way from 0 to 16, and when I try to sort by Play Count, the numbers are still all mixed up.
I hate to not be done with this, but it looks like it's not respecting the "keep tracks in order when shuffling" setting now. I just went back through to make sure everything's set as it should be, and they're still being separated.
does it still happen if you re-enable automatic refresh ?
