Author Topic: [API] MultifieldQuery, getting all Playlists  (Read 3082 times)
snwflake
[Thx for moving!]
Good moring,
I spent probably the last 30 mins wondering, if there is no API function available for getting the current track.
The closest I got, was getting the index of the track in NowPlayingList but that was it...even though I had a number, I couldn't do anything with it.
Edit: NowPlayingList_GetFileProperty did the trick  ::)
The second thing I wanted to ask, was if there (is)/will be any API function to query multiple fields e.g.:
(pseudocode)
Code: json
   query: {
      field1: {
         title: "Some Title",
         comparator: "Is"
      field2: {
         artist: "Some Artist",
         comparator: "Contains"
Would love see that coming!
I just came across another problem  :-\
I wanted to clear the current NowPlayingList and add an entire album to it. I was hoping to find something like NowPlaying_AddTitle, but what I ended up with was, getting the album, iterating through the tracks and NowPlayingList_QueueNext 'em. Which isn't that bad, but if I, say, wanted to listen to the album random, that wouldn't work.
I guess there would be no way around shoving all those tracks into a new playlist and playing that one instead?
Well...again my brain wasn't fast enough. Just shuffling the track array before queueing it => done.
Yet another problem, HOPEFULLY the last one:
Any chance searching a Playlist by Name, even better, searching playlist by wildcard so that an array of playlist will be returned?
Thanks in advance,
cheers!
Last Edit: March 03, 2017, 02:11:36 PM by snwflake
