Author Topic: Where is the volume control in "Compact Mode"?  (Read 3324 times)
PurpOp
There's a volume control in the main window, even one in the mini player, but not the compact...Am I missing something? Also, where is the STOP button in any mode???
i suggest you post a screenshot of your Compact Player setup
Stop button is toggled by pressing Shift
PurpOp
Well, I have a screenshot, now how do I send it? It's a .png file.
Bizy
More than two years later, yet still having the same problem (no way to control the volume).  (And I can't find anything more recent on this.)
https://imgur.com/a/YPEezbz
Full installer Version 3_4_7805
Portable Editon 3_4_7805 P
OS: Windows 10 Home Edition
Click on the volume which will pop up volume slider, or the mouse wheel scroll works right over there.
@Steven;
There's a visual glitch with volume level if you keep changing the number.
Bizy
@Redwing:  I can assure you I click on volume in every possible way, left, right, scrolling, moving... (up and down, left right) Nothing happens...
Bizy
I just discovered that the 'volume box' appears when I change transparency:
But I can't change the slider.
Normally, I don't use transparency, and then the box never appears.
(That's why 'where is the volume control?' was a valid question.)
These are my present settings:
b.
Last Edit: April 22, 2019, 03:21:27 PM by psychoadept
I fixed your images. If the link you're using doesn't end in .png or .jpg or whatever, then the img tag won't work.
i didnt see this post - its fixed now
Bizy
@Psychoadept:  thanks!  (sorry for not doing this right - I'll do a test to make sure I do it right next time)
@Steven:  thanks for fixing!
Bizy
@Steven:
its fixed now
Maybe, I got you wrong there...?  Same behaviour in the latest version (3.3.7051) (at least with me).
b.
Bizy
Just found out that it's the 'always on top' setting that makes the volume slider unavailable.  Without that setting, the slider pops up and works fine.
b.
