To my knowledge, you can only locate one file at a time. Each selected file would need to be found one at a time, so if you had your entire library selected and tried to find them all you would tie up your computer with this task for a very long time with no way to cancel it. Plus, you'd have a new window for every single file found. Windows API limitation, if I'm not mistaken.
