Author Topic: what is the best way to store musicbee settings?  (Read 6378 times)
Gothmoth
what files do i have to backup when i want to save the musicbee settings (interface changes, preferences etc.)?
i spend a lot of time configuring musibee.
how do i best store these settings?
File > Library > Backup Library will back up the settings folder to a location of your choice. You can add additional folders/files to back up.
For instance I back up my playlists and plugins folders. At this point I'm pretty sure you can't save your layout, unless it's stored along with the settings folder. But with the new panel arranger it's pretty simple to restore your layout. If you're truly concerned about the layout, take a screen shot and store it with your backups.
Gothmoth
thanks for your answer. but im not sure if i get what you wrote in the quote.
i want to save the UI layout but also all the other stuff i changed in the preferences.
so in case i do a fresh installation i donĀ“t have to do all the tweaking again.
last time it took a good hour until everything was the way i wanted it.
so there is no global settings file that stores all the musicbee related settings?
i am not concerned about downloaded lyrics, artist pictures etc.  just the musicbee settings.
Correct - there is no one 'settings' file. Nor is there a way to save the UI layout.
You may also find this page helpful: http://musicbee.wikia.com/wiki/Backup_%26_Restore
