Author Topic: Bug when saving EQ Preset .SDE file  (Read 933 times)
mtech
I tried to save my Custom EQ settings under Windows 10 Ver 1607 and got this error
MusicBee v3.0.5864.37328 (Win10.0), 4 Feb 2017 10:51:
System.UnauthorizedAccessException: Access to the path 'C:\Program Files (x86)\MusicBee\Equaliser\****.sde' is denied.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at #=qVcsmjclwgJ6ka94VszbS66Fimp32eaAyE94wDtk4T3GgpPDUYATjcuaV6DdpkdZr.#=qVUyVZDgmxwcmIrB74uaUgw==(#=qofcm8sIYWLYgYsRYAz0tHvrPZec$yWYe6sOuIQZHewC1G9XZqzeyf0HXwuA7RwSn #=qhMwdgl0b4mNb6GoZ3OnlAQ==, #=quG1VrD$vJ6ZTplNx5c56Iw== #=q6TX4Si7v_oCV52lFvIQeJw==)
   at #=qCsTMHrtTL9fCUQSvQtUWloRe16fi9FS0nafABozHVtXzvxYJH1Pzs20qO_oi8IFP.#=qxUHpINsNegkwX5GbAtPGm4OnaYSPr7Cnuf5aTAH9rrk=(Object #=qooP058SsWpY$ZtSSC1yoCg==, EventArgs #=qUDcLBWMtV4c0Zg5BGORWWw==)
   at #=qYokz$4528jpYtcwzt5ym7LIRibwCYEIGjAy19NLLV3E=.OnClick(EventArgs #=qhm9ef7WK67bRLBgIE9NqXg==)
   at #=qYokz$4528jpYtcwzt5ym7LIRibwCYEIGjAy19NLLV3E=.#=q4_lYR9wjcgdkdHkdkn378eVDFbTDyu6r_bY6Qx3DARc=(Object #=qXS7y8x7AL980W97V$DI9yQ==, EventArgs #=qeWyHP$GYpO0$iSapDhJuKQ==)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
firstly you should update to the latest patch version from the first forum topic.
In any case, you dont have write permissions to the folder so would need to run MB as an administrator to be able to save the file. Also *** is not allowable as a file name
edit:
I forgot to mention v3.1 already has handling to ensure the equaliser files are always in a writeable folder
Last Edit: February 04, 2017, 10:50:32 AM by Steven
