Author Topic: Change/Skin File System Icons?  (Read 1279 times)
drjee
is it possible to change/skin the icons of the drives and folders of the file system/computer folder (in the left pane)?
If not, please, implement this skinning feature.
thanks, drjee
ps: otherwise: great look/skins that you provided!
I'm pretty sure that that is not possible at the moment.
if it is important to you, it would be best to post a request for it in the existing 'Skinning Requests' thread under Support > Developers' Area > Skins.
(or if that specific request perhaps already exists, +1 it.
drjee
