Author Topic: Send To > Device. Possible bug (not tried before)  (Read 1351 times)
stewlewis
Using v3.0.6239 portable.
Trying to 'Send To' from USB stick to my Music folder on my internal drive.
I sync the stick with files according to a playlist and rules, then I want to copy the files back to my main folder.
The 'Send To > Folder' options are greyed out when trying to copy or move a file from USB stick/Device\Music to my main music folder.
2 way sync is greyed too.
I setup my main music folder as a virtual device and used 'Send To > Device' to send a file back to my main music folder. - worked OK.
Trying to send another file from USB to Virtual Device (my main music folder again) - greyed out, until I close the tab and open a new one for USB Stick/Device\music.
F5/Refresh doesn't help.
Is that a bug?
Can I get 'Send To' from USB to folders enabled?
Can I get 2 way sync from USB stick or HDD enabled?
Can that be done for USB drive connected as ESATA?
