Author Topic: How do I? Date modified rule...  (Read 1045 times)
stewlewis
Would anybody know how to filter for an organized copy using date modified and date created?
I'm taking files from my library and Send To:Copy copying them to an external, renaming as I go and putting them all in one flat folder.
These files may then get tags modified with another program, Serato.
I'll then Send To:Move(or copy) the files back to my library, renaming and sorting as per my default library rule.
Question. How do I only copy the files back to my library(internal drive) that have had tags updated?
I'm guessing something along the lines of, Move files back to library(int drv) (renaming and sorting as default rule) ONLY if Date Modified is > Date Created. That way if the file was modified after it was originally created on the external it would have been changed after date added to my library = it would get copied.
My problem is I can only see Exceptions, and can't do eg. date modified > original date modified on file to be overwritten.
They may be a better or easier way, but I'm now just confusing myself.
