Author Topic: User defined URL / WXXX  (Read 2163 times)
𝑴𝑬𝑷𝑯
How do i setup custom tags to read the ID3 from a user defined url / WXXX?
  • MB Version: 3.6.8849 P
basic custom tag instructions are here: http://musicbee.wikia.com/wiki/Custom_Tags
𝑴𝑬𝑷𝑯
Anyone know the answer to this, because i can't figure out.
I see that MB is writing to/looking for  TXXX/WXXX when WXXX is set up as a custom tag.
You have 2 options:
1/.  Put a wishlist entry in for Steven to add WXXX as an in-built custom tag
or
2/.  Edit your CustomTagConfig.xml file and remove the preceding TXXX/ from the id3v23/id3v24 entries.
Hope that helps  :)
𝑴𝑬𝑷𝑯
Thanks for the reply.
I've tried your options, but it didn't work out for me. Maybe the wishlist entry might eventually do the trick.
