Hi, first I have to say what a great program MusicBee is, I've just started with it and it looks to be perfect for my workflow.
There's so much to it, yet so professional I'm sure it's perfect for everybody's workflow!
I've just started and I'm using MB for music file management so far, to then send files to external storage for Serato DJ use.
Is there any way to name a file org/send to/copy to organised preset? Rather than just the path and file template, and have the check boxes and path remembered for each preset.
Using the files in Serato they are analysed and tagged with BPM and Key automatically and I may change or add tags as I'm using Serato.
Once I have my files on the external what would be the easiest way to copy those files with updated tags, back to their original locations?
If I use the USB as a device 2 way synchronizing is not available.
PS. Is the Send to, move, organised folder the same thing as the file organiser CTRL+R?
Thanks knowledgeable users and thanks again to the developer.
