Asking here before I post it as a bug, in case I'm missing something obvious, but while in my Inbox, I can right click a track, chose 'Send To' and then 'Folder Move/Copy/Replace'. That works great.
In my actual library tab, I can right click on the item, select 'Send To' and then I can only 'Folder Copy/Replace', the 'Move' option is greyed out.
Is there a special requirement or setting I need to enable it, or is it a bug?
I'm on version 3.0.6190
Cheers!
