So I get some distortion on certain songs when the EQ is on, but lowering the pre-amp and playing with the other sliders can get rid of it.
The problem is every time I change tracks it goes back to where it was before. When I look at the equaliser is still looks the same but I can tell it's different.
For example the pre-amp is at -3.3, it sounds good, then it goes to the next track, distortion. I open the equaliser and slide the pre-amp UP, yet it gets quieter. Which means the pre-amp was at even higher even though it says it is still at -3.3
I tried saving a setting, and after it skips to the next track I re-select that preset it's already on, and again it gets quieter.
