Author Topic: Error when syncing music  (Read 1578 times)
thryd
Hi, first time poster to this forum, so apologies if i am posting in the wrong section or if my formatting is wrong.
I am having issues with syncing my music to my Galaxy S4. I am converting my flac files to mp3 using the high quality encoding profile. Below is the error message that i get.
MusicBee v3.0.6132.15853 (Win10.0), 6 Jan 2017 1:48:
System.Runtime.InteropServices.COMException (0x8007070C): The specified datatype is invalid. (Exception from HRESULT: 0x8007070C)
   at PortableDeviceApiLib.IPortableDeviceContent.CreateObjectWithPropertiesOnly(IPortableDeviceValues pValues, String& ppszObjectID)
   at #=qAhpBkeE1O5pWpQ1i2f0$dCn9$JSXK1IS9yz6dWTpEuq9b13_LJWxiBzxC0vasJds.#=qIg5J8zIg7mJLdL3MpX2fm6JN9AEVxYMn0ZyM0kqrmpQ=(#=qyXmV84TNZ9kJvSLzbwE0vBrPx$BhuHFnDIuB$gA8q54= #=qN_vS56URRk$tWjneltmRGg==)
   at #=qAhpBkeE1O5pWpQ1i2f0$dCn9$JSXK1IS9yz6dWTpEuq9b13_LJWxiBzxC0vasJds.#=qKJKdDcnc6MZjGBm8dz5AJQ==(#=qyXmV84TNZ9kJvSLzbwE0vBrPx$BhuHFnDIuB$gA8q54= #=q_AYT7O2UjENq1m_8FXgYcw==)
   at MusicBee.Media.Storage.#=q3paACOLVPglz$IPMSdgWyA==(Boolean #=qVFq98jKpD_nYbQKN1BmNDw==, Boolean #=qEr0NWedYxD1hL57R6JNaiA==, Dictionary`2 #=qLbr_h7nPHXlicI1SZHdTbL6vjUcnamp0rXYrl5jbDT4=, List`1 #=qRPtDJve3BJbx8DHGzGR2SASXMQMh4jtKWXHLbnr96RQ=, Object #=qsc8h5HjYGDdHt9T31zcenWDdxYwGnDI8LPz84pbd$uc=)
   at MusicBee.Media.Storage.#=qiaNYGW61wXypH019Ax_c2A==(Boolean #=qhZrNgMoFtp1Xt4xQzRF3BA==, #=qRo9BMvebBCa$_whkMEV0_tXo$$nUHMmM$SUbz043_Dg= #=qkDjR5$cjVSeZfbBQRqdRJw==, Object #=qqckhCn$0bJeemo7LqtqBLSPx1PYEmfYAtv1oGqLXPqI=)
   at MusicBee.Media.Storage.#=qqKQ7BWLQo8LfyCV6EDuEMQ==(Object #=qK1QpdMNFpmCQDdkfRoe_wKuPmeuov3q6Vn1gJLWCXnQ=)
   at #=qSmsCKAIpwZ6zf3hGTiH334fjEjJSmfDh9mM76YeTBwI=.#=qYkJknxnaTzrN38YOJwS$GnvgjD3IPci3OPoZJPuBSCU=(Object #=q0y969Y$tJsDUuXGel3KVzA==)
Thanks for the help.
the error is happening when MB tries to create a new folder on the device. If the error happens repeatedly then i wont be able to help and recommend you try a different application for synching
thryd
Thanks for the info Steven, I think the issue might be my phone actually. Syncing my tablet works fine.
Lambert
I too started getting these errors
but only for playlists.  The fix, if you can call it that, was to decrypt my SD card. I'm not sure exactly when I did encrypt it, I know it was recently, but I thought I'd done a sync with MusicBee since. Perhaps not. This was happening with my Galaxy S8.
