Author Topic: How can one display the files grouped by folders?  (Read 11694 times)
Donk
Windows 10 Home, 64bit | Portable MusicBee
If you don't want to use the computer node, which shows the actual folders, you could sort by Path
wobbly
more info please
CritterMan
  • Now with FiiO M11!
Check out Sorting under Sorting & Grouping in the wiki.
wobbly
cool thank  you .. i did not know you could set your own Sorting & Grouping
CritterMan
MB has so many features, one can be forgiven for missing most of them. I discover them from time to time by keeping an eye on the forums.
wobbly
iam reading as much as i can ...  sometimes  a question will come  up that helps  me understand a bit more
iam on here everyday
Asking questions is of course a very good way to learn, but exploring and checking out available MusicBee settings, and searching the forum and wiki for existing topics and explanations on those first is probably even better.
About your original question here:
You could also try out if:
Preferences > Sorting/Grouping > 'files for each album are organised in their own folder'
is what you are trying to accomplish here.
Last Edit: January 01, 2017, 10:24:43 AM by hiccup
wobbly
I looked at that but I found it works fine for some albums but  not good for albums with cd1 cd2 cd3  folders and so on unless i am missing something does  musicbee  know to treat sub folders eg cd1 cd2 cd3 as one album
my folder are like this eg
ACDC\Live (Special Collector's Edition)\cd1
ACDC\Live (Special Collector's Edition)\cd2
or is
musicbee looking for folders  disk 1 disk 2
Last Edit: January 02, 2017, 01:06:09 AM by wobbly
or is
On my system all folders and all it's sub folders are displayed with that setting.
So it might perhaps be some specific naming or sorting issue on your side?
wobbly
how are the albums displayed ? for me I  see all the albums but cd1 cd2 show as 2 albums in album view  how to group  cd1 cd2 as one  album  with this setting ..  some albums have uptp seven cds
Donk
Thank you very much!
If you don't want to use the computer node,...
No, no, where could I find that computer node?
...you could sort by Path
I assume,those means the same. I have done that:
How could I group the panel on the left by path now? Where can I find: "that are available from 'Sort By' menu"?
Many thanks again
CritterMan
That's exactly what should happen if your discs are in separate folders. That's what defining an album as all files in one folder does. If you want them to appear as one album, all tracks must be in the same folder or you need to use the other option of defining an album.
Display MB in full-screen, then move your mouse cursor to the left side of the screen and leave it there until a panel pops out from the left side. Click on Computer, that's the node.
The option you have selected in the screenshot does not group by folder (path). It groups them by the Album Artist tag and then the Album tag in the metadata of your music files regardless of the folders they are in.
When you reveal the left sidebar (by moving your mouse to the left) you can use the computer node as I already described to navigate your folder structure. There is a little pin icon at the top right of that sidebar that allows you to keep it visible at all times if you want.
The left panel in your screenshot doesn't support folder navigation unless I am mistaken.
Donk
Thank you very much.
Yes, found the computer node and the pin.
And under 1. in the screenshot near "Sort", how could I show that path in the left panel or else?
Many thanks again
CritterMan
You can't display that in the left panel to my knowledge. At the top left of the main panel, click on whatever word appears there for a menu to apply custom sort settings.
