Author Topic: How to monitor music folders / files / add new music files / ablums to library?  (Read 5255 times)
Donk
Why does MB not scan the music folders / files / add new music files / ablums to the library:
Windows 10 Home, 64bit | Portable MusicBee
Donk
Many thanks.
No, I am not at all, where / how could I do it?
Donk
Thank you very much.
I understand, the wrong setting checked, now it is like this, still nothing happens (after re-starting MB):
Obviously I am missing anyhting, but what?
Many thanks again
I am guessing the files you are looking for are now visible in your 'Inbox', and will not be considered as 'new files' anymore.
So you'll have to move them from your Inbox to your library.
Donk
It appears there is no file in the Inbox:
CritterMan
  • Now with FiiO M11!
Try dragging and dropping files into MB for now, new files should start appearing when placed in your Musik folder going forward.
Donk
Thank you, CritterMan,
I had just re-added the music folder, now it seems to work.
Many thanks again
