Author Topic: how do i have the file structure visible on the left  (Read 751 times)
redhaze8080
hey,
I did a Windows reinstall .. and i can't figure how to get the file structure of my /music folder as the far left vertical menu..
has something changed or am I a bit slow today?
Hi, welcome to the forum!
I think you're looking for the Computer node in the left navigator.  The Computer node is active by default, but the left navigator is on auto-hide mode for a fresh install.  If it's not showing up, try hovering your mouse over the left side of the window.  Then you can "pin" it to keep it open.
