Author Topic: Small wishes about bitrate  (Read 2668 times)
1. Can you make bitrate field available for column browser? That's useful when you want to filter tracks by bitrate. Currently I have to use a virtual field instead.
2. If the columns get a little crowded with many fields, "Auto Size All Column" command often shows just first digit for bitrate. Can you make the field show at least three digits when auto-sized? Compare how it looks when auto-sized with when it's defined as virtual field.
HHM
+1
and the column header could be BTR instead of Bitrate, so it would also have 3 letters
+1
maettu
Same wish. I want to sort for all "bad" encoded files, thus require a field to sort according to bitrate.
Workaround:
Go to Preferences > Tags (1) > Define New Tags...
Define a new tag with label = "Bitrate" and formula = <Bitrate>
maettu
Related to this topic, I'd like a bit more clarity regarding relationship and differences of items/terms "Custom Tag" -vs- "Virtual Tag" -vs- "Fields".
maettu
Just realized that 'Bitrate' actually exists, it's just located under 'Common Fields' instead of 'Other Fields'. Sorry for missing that.
