I guess I could just pass in the DiscCount as is already being done. Whatever works for you. Any idea when you can make the change to support the multi-disc result?
I finished designing an algorithm to convert most of the various discogs position number formats that could result from supporting different types of multiple disc and multiple format releases. It wasn't easy, and it won't cover every single case, but I think my design will work for 99.9% of them. If it all works out, the plugin will be able to split the following different types of position values into separate discs and tracks:
A1, A-1, CD1, CD1-1, ALPHA1, LP-A1, 12"-A1, 10'' A, LP A1
I will also be handling mixed media that often comes in box sets such as CD + Vinyl or CD + DVD. In order to do all this I will write code that detects disc or side changes, combines two consecutive sides into one disc (i.e. side A followed by side B tracks both go on one disc), and auto-number the discs and tracks based on order of appearance and not use the actual value in the position field.
Here is an example of how my changes will convert the following sequence of track positions from discogs format into DiscNo-TrackNo format:
Input : A, B1, B2, B3, C1, C2, D, E, CD1, CD2, CD3, CD4, DVD1-1, DVD1-2, DVD2
Output: 1-1, 1-2, 1-3, 1-4, 2-1, 2-2, 2-3, 3-1, 4-1, 4-2, 4-3, 4-4, 5-1, 5-2, 6-1
I think this conversion is the best way to handle it. What do you think? Would it make sense to display the TrackNo, TrackCount, DiscNo, and DiscCount columns in the track match up table? I've often found myself wondering what values the auto tagger found before committing to apply the tags.
