You might have just as much luck using the Rock or Techno equalizer presets in MusicBee, they are very similar to what you have pictured.
If you look at the bottom of the image you shared, you can see the value of each slider expressed in +/-#,# dB. In this case, the comma means the same as a decimal point. When you move a slider on the equalizer in MusicBee, a little gray rectangle will appear to show the value you are setting it to. If you hover over a slider, the same indicator appears. Use the 10-band option, ignore the preamp (left-most slider in your image), and adjust each slider to the values you see in your image.
Because no two audio setups are the same, the equalizer setting will not produce exactly the same sound on a different system. If you'd like to learn how to adjust your equalizer from scratch, there are about a million tutorials online you can play with.
