Author Topic: Improvements for Classical Music Support  (Read 46077 times)
vincent kars
That is indeed a better way to store the pics.
Changed the webpages
Thanks
Vincent
for the next v3.1 update i have changed the sorting of custom and virtual tags to account for text ending in a number
i will consider the ideas around defining a composition at a later point
orgelwerke
name: Work & cat.nr. °
$IsNull(<Show Movement>,<Album>,$IsNull(<Work>,$Split(<Title>,: ,1),<Work>))
$IsNull(<Show Movement>,,$If($Contains($Split(<Title>,: ,2),-),$Split($Split(<Title>,: ,2)," - ",1),))
Would it be possible to make a virtual tag which would include Work, Cat.Nr and Act/Movement? I've been trying to figure it out, but without any luck.
Last Edit: April 02, 2018, 02:53:34 PM by psychoadept
]Would it be possible to make a virtual tag which would include Work, Cat.Nr and Act/Movement? I've been trying to figure it out, but without any luck.
If you have already setup these two virtual tags, you could just add a third one concatenating those like this:
Virtual Tag 3: <Work & cat.nr. °>: <Act/Movement °>
Or, as a dedicated formula I think this should work:
$IsNull(<Show Movement>,<Album>": "<Title>,$IsNull(<Work>,$IsNull(<Work>,$Split(<Title>,:,1),<Work>),<Work>", "$If($Contains($Split(<Title>,: ,2),-),$Split($Split(<Title>,: ,2)," - ",1),)))
orgelwerke
This works great, but only if I have something under the Act/Movement tag, otherwise it puts "Unknown Act/Movement"
Quote from: hiccup
This one shows only the Work & Cat.Nr., without Act/Movement.
I think I need to clarify why am I asking for this additional virtual tag  :)
My operas look like this:
La traviata: Atto II. Scena II. - "Avrem lieta di maschere la notte"
but, I don't put "-" after the number of movements in other classical pieces, so it goes like this:
Symphony No. 3 in E flat major, Op. 55 "Eroica": I. Allegro con brio
so basically I don't have "act/movement" here because the numbers are attached to the title/selection tag
I thought if I put Work + Cat.Nr + Act/Movement as Sub-Grouping header, it would work nicely for both. Idk maybe it's not even possible  :(
Last Edit: April 02, 2018, 03:04:17 PM by psychoadept
I removed the font color on your posts because it's unreadable in the dark forum skin.
Does this work for you?:
<Work & cat.nr. °> $IsNull(<Act/Movement °>,,": "<Act/Movement °>)
orgelwerke
Yes!  :-*  Thank you very much!
P.S. Sorry about the font color, when I went to preview it was a very light grey, that's why I changed it.
