Author Topic: Persistent Window Locations  (Read 5520 times)
Thanks!
the above are done now. However for the double clicked large pictures, MB will try to use the same location but if the picture falls outside the screen bounds, the location will be adjusted to fit the picture
Thanks very much Steven.
'Track Information' configuration is not remaining persistent.
I can open it two ways:
Preferences > Layout (1) > right sidebar > track information > customize layout
And with the 'Details' panel in the right sidebar, click on 'Details' > Customize Panel.
Interesting that the config panel opens in different positions depending on which way it is accessed. But moving either to my preferred position does not remain persistent.
Another window that should be made persistent: Locate Missing Files.
Thanks.
Thank you Sir Speedy!
@Steven...
Tools > Locate Missing Files window, which was fixed with the patch of April 4, is now not maintaining its position.
Boroda74 has taken care of this: Nor are any of the windows from the Advanced Tagging & Reporting Tools plugin. Please advise if I should inform boroda74 about those.
Last Edit: April 24, 2017, 02:52:37 PM by phred
@Steven...
i cannot reproduce that and havent changed anything for that dialog
Using 3.1.6322...
http://i.imgur.com/4oDgW6f.gifv
the functionality is only implemented for the input windows, not the message popups
So either I' m imagining that that particular window was persistent previously, or the resulting window actually returned some missing files.
Thanks for looking into this Steven.
