Author Topic: how do I listen to playlits?  (Read 1587 times)
shadowdrake14
I've been listening to music on musicbee for a while but somehow i broke something. on the left where it used to have a "library" option and my playlists now it says "genre category" and none of the option will take me back to the view that had my playlists.
Hi, welcome to the forum!
Your left navigator panel is probably hidden.  If it doesn't pop up when you mouse over the left side of the screen (from which point you can pin it open), you will need to go into panels configuration (button next to the search box) and unhide it.
shadowdrake14
Did you follow the steps I suggested for restoring the left navigator?
shadowdrake14
I wasn't sure what to change. http://imgur.com/a/d9JZT this is a screen cap of the area i think i'm suposed to be in but idk what to change I think the left navigator is still there just displaying other stuff
This has the details on showing/hiding the navigator: http://musicbee.wikia.com/wiki/Auto-open#Tab_Overrides
It is possible that it's "behind" the panel you showed, but that's not the default configuration.  You would have had to set that up yourself.
