If these are compilations, you can mark them as iTunes compilations with the tag editor, and set "treat itunes compilations as..." in sorting/grouping preferences. I'm not sure you can make them truly blank, but you can set the compilation value for album artist to anything you like. I use [compilation] so that they sort separately from the rest of the library.
