When I click on the artist I want to see all of the albums, and all of the tracks, at the same time. What you told me to do shows albums until I click on an album, and then it shows the tracks. It removes the way to see all tracks without clicking albums.
Maybe an image will help explain.Albums and Tracks kind of does what I want I guess... but its hideous to look at with all the space in between albums.
Also,
my left and right panels keep resizing when I open the program? (
How I want them.) Why won't they stay how I put them? This may be a deal breaker for me if they can't lock.
EDIT: I somehow managed to deleted my first edit. I want a way to refresh changes I make in mp3tag in Musicbee in the background.
Winamp has this option I always would use.EDIT 2: I found how to make it do this in the background, though I still need to click proceed........... but it isn't updating the tag changes I am making... idk.
The tags on the left are the only ones on the file. I went in and manually cleared out everything else. I don't understand where the extra album artist tag is coming from unless this (insert) isn't how you refresh tags on Musicbee?
EDIT 3: I just closed and reopened it to see if that would fix the tags and...
it resized the left and right columns again.....
EDIT 4: I am seriously so confused where the Japanese album Artist tags are coming from I cannot find them anywhere in my files.....? I can just remove then in Musicbee... but I don't want to have to do that every time I get a new album that I already ran through mp3tag.... I am baffled.
EDIT 5: Okay, I found
this finally. Finally it makes more sense. I guess I will just need to find a way to remove APE tags? Is there a way that I could just disable them in Musicbee?
EDIT 6:
Leaving this here in case anyone who finds this thread needs it. I would still like a way to disable APE in Musicbee if possible.
