I'm another DJ who would love to move away from iTunes bloatware, I already use MusicBee to edit and "sanitise" mp3 files before importing them into iTunes, but would love to be able to just use MusicBee with it's simpler interface and ease of use, I use Trcktor for DJing and tried the itunes xml export a while ago with some issues, sounds like things have since moved on, would you say MusicBee is at a stage where it can replace iTunes for organising playlists for use with Traktor? Can MB import my existing iTunes library and playlists safely? including smart playlists? (I also have several years worth currently in iTunes). Finally is there a guide to doing the above?
Many Thanks in advance,
Phill.
