Hello all
Running MB 3.0.5995.
Just had to reinstall my PC, and before that I backed up my MB EQ settings and playlists.
I got the music and EQ settings imported right after re-install, but I am having an issue importing the playlists. Note it's the same version of MB after the re-install.
When I go to the File menu to import playlists, it's not seeing anything.
I figured out it's because the backed up playlists are saved as MBP files, which apparently cannot be imported directly.
Does anyone know if there is a workaround to this?
With respect,
Soren
