The left navigator is in auto-hide mode. To disable that, you can use the "pin" button on the top right of the panel.
Quote from: psychoadept on September 26, 2016, 04:05:34 PMThe left navigator is in auto-hide mode. To disable that, you can use the "pin" button on the top right of the panel.Isn't it more like this?
