Author Topic: Way too much CPU drain over time.  (Read 1614 times)
LazR
It seems like MusicBee is using way too much CPU over time. It doesnt start off using so much but after 1-2 hours, then it gets up to it. I have an AMD A4-5300 (yes I know shit) with a ASRock FM2A55M-DGS MoBo and a GTX 750ti GPU.
https://gyazo.com/93514a9d80a8399d8d0f0bc18b855d16
  • MB Version: 3.5.8402 P
and what version of MB are you using?
LazR
I am using MusicBee 3.0 and the latest Patched Version. (v. 3.0.6079)
the amount of memory being used is also extremely unusual as well.
I have seen myself that when playing web streams a lot the CPU usage goes up very high but i have never been able to trace it to MB code, so its something in .NET or in windows so i dont think i will be able to help
