Hi there
Loving MB so far,
however every time i perform the action "add to playlist" on a track
the Expanded Panel tracklist (in the main panel) is immediately closed
but only if it is set to be shown "directly under the selected album"
(if tracklist is set to bottom of main panel it just adds to playlist as expected)
Additionally performing Add to Playlist from the Playing Tracks on the right side-bar
will also close any (unrelated album) expanded tracklist in the main panel
Is this normal and/or any ideas on how to prevent this behavior?
thanks
