Author Topic: add rating to mini player  (Read 2192 times)
firefuego
tried editing the playing tracks layout panel and simply couldnt find an option to add rating to this.
firefuego
Trying to add the rating in between album name and song title
right click on the column header row/ Set Displayed Fields/ and then tick Rating from the common fields section
firefuego
dont see that option in the mini player. i have that set in my main player though.
firefuego
if the column header is the thing that says Artist | Title | Album etc. I can only see that in my main player. Mini player doesn't have that.
firefuego
ok, it does look like i have forgotten to provide a way the set the fields. I will look at adding a menu item for that
unzip and replace the files where MB is installed
right click on the mini-player/ Playing Tracks Layout/ Set Displayed Fields
firefuego
Awesome! Thank you so much!
