I'm a bit lost with lyrics & musicbee as of now
For example, musicbee displays lyrics fine by default but when I go to "edit track", then "lyrics" tab, it's empty
Is there a way to retrieve your whole library lyrics ?
Also in "now playing" tab in "artist picture" mode, I can't seem to either :
-increase the space available to display lyrics over
-nor increase the font size
(currently using main panel left side for lyrics but right panel is the same result)
Finally I heard about synched lyrics, I tried searching but again I'm lost
I saw there's mainly two competitors ? (right ?)
-minilyrics which relies on an external application ? (and an optional plugin?)
-& lyrics reloaded which works from within musicbee directly
is there any list of pros & cons of each ? can you guyz advise me ?
Any input appreciated,
Thanks.
Whis.
