I did a fresh install of MB in order to clear out a bunch of existing issues I had from trying to migrate things from my old computer.
Mostly everything works properly again, except for the aac file converter. I'm using the fdkaac codec which uses the following default format: fdkaac [options] input_file.
Previously I used: -m 5 -p 2 --ignorelength -S -o [outputfile]-
Everything worked great (conversion wise) up until I did the reinstall. Now I get this error:
I've confirmed that that string is correct using CMD prompt, and the other codecs (lame mp3) still seem to work ok. Any ideas about what's up?
