Author Topic: [FIXED] Musicbee stalls at first song when moving music to organised folders  (Read 5220 times)
Cypher
When using the "Move to organizing folder" function on Musicbee 3, It stalls at the first song. That song is successfully moved to the new folder but the whole operation stays at "Organizing...". I can close the window of the operation but Musicbee stalls after that. I can only close Musicbee via task manager and sometimes the close button. Musicbee gives me that the operation is still going when i can do the latter.
The "Copy to organizing folder" function isn't affected. The issue is most likely that Musicbee can't delete the music files from the source folder. The source folder wasn't locked by any other processes.
My Musicbee version is: 3.0.6079.
Last Edit: August 27, 2016, 11:27:10 PM by Melvinkooi
i cant reproduce any issues.
- Are the files already in your library, or inbox
- is your library already auto-organised
- is the target folder under a monitored folder if you have that enabled
- also can you confirm you will run a debug version if needed
Cypher
I edit the files in a separate folder outside the library. The target folder is the library itself that's being monitored by Musicbee.
Everything is organised by the "Move to organizing folder" function. Although a lot of organisation was done by foobar. It shouldn't be the issue as i get this problem without having foobar open.
Yes.
I don't know where you can download it but i will.
can you run this debug version and when MB freezes, restart and send me the info at the end of the error log (help/ support/ view error log)
http://www.mediafire.com/download/af416gxm49zba7f/MusicBeeDebugFileOrg.zip
thanks. unfortnately it doesnt help at all.
Could you re-download the same link and do the same?
Also it may be relevant if you have an ASR active from the tag tools plugin
Last Edit: August 26, 2016, 04:20:45 PM by Steven
Cypher
thanks. I still cant reproduce the issue and infact it just gets stranger.
Could you do the same again with the same link. The log might be quite big this time
