Author Topic: Now playing bar  (Read 1701 times)
zinc
It's me again. Does anybody now how to get rid off this arrow just like it was in 2.5 version?!
Last Edit: August 24, 2016, 01:51:34 PM by zinc
  • MB Version: 3.5.8402 P
without attaching an image, it's really hard to know which arrow "this arrow" refers to
zinc
Here's a couple of helpful tips:
1 - Please don't create new threads for the same issue. (You posted this same request a couple of days ago.) If you feel you're not getting a response, reply to your original thread with a "bump" to move it up in the topics list.
2 - Perhaps the reason you're not getting any response is because you're not using a good Subject title. A topic entitled "Help Me" or "Hello!" doesn't give the reader a clue about what is going on. Personally, I will usually skip over those posts. For this issue I would use something like "image help please"  or "configuration help."
Check out the MusicBee Wiki.
The "arrow" is an artistic cropping effect that Steven has introduced in the now playing bar for MB3.0.
It can't be turned off.
If the original square cropping is a 'must have' for you, would need to post a request in the "Wishlist" section to see if Steven will consider making the new look optional.
holuschi
If you do not like it you can choose an embedded Theater Mode instead of Track Information
