Hallo Bees!
I have a problem with my playlists. It's a smaller one (and I don't know if you can see it as a bug), I'll explain it with an example.
I have MusicBee portable, patched. I keep it in a folder of my NAS, so I hope to use it from various PCs around the net (of course, one at time).
Ok, when I create a new Auto-PlayList, and I choose a rule that refers to another playlist, this is what I see:
http://imgur.com/a/WitYoAs you can see, the dropdown button show me the playlist path, starting from \\192.168.0.10\etc.etc.
But the path is (not so) long, so I can't actually see the playlist name!
Well, when I actually choose one of them, then I can finally see the name, but of course trying to guess the right one isn't a good way to use it.
So, is it a problem of mine version? Can I make something to fix it? (I tried to choose "use relative file paths" in Preferences>Library, but nothing changed (and of course I'm not sure that option could be useful or not, with my Portable version).
I hope you can help me! Thanks in advance.
