Author Topic: Increase the witdth of the progressive bar  (Read 6083 times)
Adson
It would be nice to have a broader progress bar (the line which shows how long the current song is playing).
I find it sometimes a bit difficult to hit the bar with the mouse cursor because it's width is only 3 pixels which is very small when using a monitor with a high resolution.
A.
are you referring to when the player is docked in the right sidebar?
Adson
... no, the player and the progress bar are at the bottom of the MB window.
If you like I send you a screenshot via PM.
I have already tested if this may depend on the skin that is used but it stays the same no matter which skin I use.
A.
please send a screen shot. Someone else has asked the same, and he is using 125 dpi rather than the usual 96 dpi.
I wont be able to look at it this week though
Adson
... I wonder if something has changed regarding this topic? I run Beta 3940 and the progress bar is still very! thin.
A.
i plan to do this before the final release this year but might be still a few weeks off
i've changed it so it increases the progress bar width for screens with > 96 DPI resolution.
If you still have the problem, i can add a setting so you can force it to use the larger size
hdradio
I am using the latest beta 1.2.3992
I 'd like also a larger progress bar too
