Author Topic: Librarys and Audiobooks  (Read 4005 times)
/lasse
I’m new to MusicBee so I don’t know if it is already possible.
The thing is I have made two libraries’ one for music and one for audiobooks, in total about 70 Gb.
I use to sync with Android. But the playlists are  in separate library’s but the device setting is one for all.
So when I sync music I have set do delete tracks not in the sync list. That will delete audiobooks synced in audiobook library. So I have to also resync the audiobooks playlists (and remember to tick off delete tracks not in the lists).
Is there some way to get around this?
But MusicBee seems to handle large amounts of files easy, so maybe it’s better to have it all in the same library?
Anyhow it had been nice if one could select books to sync, especially if there is about 35 Gb books.
You don't need a separate library for audiobooks; there is a separate audiobooks node for that purpose.  If you don't see it, you can turn it on in Layout Preferences. Having them all in the same library will make it much easier to manage.
