Author Topic: Podcasts Mixed in with Music  (Read 2089 times)
frankr
In the device configuration of my portable device, my default storage path is:
Portable Device\SanDisk SD Card\
with "use naming template" selected, my podcast files should be copied to:
Podcasts\<Publisher>\<Title>
Therefore, the full path to my podcasts should be:
Portable Device\SanDisk SD Card\Podcasts\<Publisher>\<Title>
However, when I synchronize MusicBee with my phone, MB puts my podcasts into:
Portable Device\SanDisk SD Card\Music\Podcasts\<Publisher>\<Title>
I don't have any playlists set up and I just want play my music on shuffle on my phone.  However, because Podcasts are placed within my Music folder, the podcasts end up mixed in with my songs.
I download my podcasts from iTunes so they are located in:
d:\Users\Frank\Music\iTunes\iTunes Media\Podcasts
How do I correct this situation?
Could you post a screenshot of your sync templates?
frankr
I don't see any option in my reply screen for formatting or attaching files.  Is there a minimum post count for this?
Yeah, that seems like a bug.  MusicBee is using the default template rather than yours.
theta_wave
Sorry, but I am unable to reproduce this in the latest build [6052].
Settings:
Result:
frankr
I've updated to the latest version of MB and podcasts are now being copied to the correct directory in my phone.
Problem solved. Thank you.
