Hi everybody, I'm new here, so I may be missing something. I looked all over the place and couldn't find a solution, so:
I just started re-ripping my library in OGG format, replacing old 128kbps files with the new ones. However, syncing the updated library with my device prompts to delete many files, which were untouched, and I'm sure they're the same, since I used to use WinSCP to keep the two libraries synced. I can't figure out what I am doing wrong.
The only thing I can think of is a filter I applied, in order not to sync a couple of albums. Apart from that, all the settings were pretty much left untouched.
Can anybody help me?
