if they are MB library playlists then even if you choose M3U as the format in the Library preferences, MB would not save the #EXTINFO
if the playlists are created by exporting a static copy from an MB library playlist, then you have the option of choosing M3U#EXT for exported playlists in the Library preferences which would write that info.
Otherwise many software applications can write that info to an m3u playlist
