Author Topic: Using external recommendation services in MB-Player?  (Read 1254 times)
Alsweider
Is there any way to use recommended songs from sources like Last.fm/Pandora/Spotify directly in the MB-player? Would be pretty handy to get recommendations and be able to rate/sort/add them to your library instantly.
Last Edit: July 12, 2016, 06:25:33 PM by Alsweider
Check recommendations node under Service in the left navigator. Also try last.fm recommendations plugin which will show up under Services too when installed.
