Author Topic: WAV tags: sample & bit rates  (Read 2355 times)
Damo
Hello again!
Another thing I've found when importing WAV files that have been mixed down in Cubase is that MusicBee shows both the sample rate and bitrate as Unknown! Is there any way I can effectively re-tag these files with this info?
Thanks again in advance for any help!
Leroy Bad
I started downloading some albums in WAVE and also noticed that some properties are unknown also.
Do have or are you able to put the file on a server, or even open the file in a hex editor and send me the first 100 or so bytes ?
Leroy Bad
I just noticed that the only waves missing the properties are those that are 24-bit. 16-bit waves have all the information.
Leroy Bad
Not sure how to send the HEX info , but here are the first 128 bytes.
Offset(h) 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F
00000000  52 49 46 46 46 ED 24 03 57 41 56 45 66 6D 74 20 28 00 00 00 FE FF 02 00 44 AC 00 00 98 09 04 00
00000020  06 00 18 00 16 00 18 00 03 00 00 00 01 00 00 00 00 00 10 00 80 00 00 AA 00 38 9B 71 66 61 63 74
00000040  04 00 00 00 FC 25 86 00 64 61 74 61 E8 E3 24 03 EA 00 00 C4 F9 FF C7 00 00 16 FC FF 8E FB FF CA
00000060  FA FF 6C FF FF 3D FC FF F6 02 00 31 00 00 1A FF FF C1 FE FF 00 03 00 06 FB FF A4 00 00 6E FD FF
that doesnt appear to be a PCM wave file. The specs i am looking at dont indicate what format that is.
If you can play the file then i can look at using the bass library to retrieve that info
Leroy Bad
It shows as a 24 bit WAVE Audio in MusicBee. It plays fine.
Perhaps I have the HEX editor showing the wrong info? I wasn't sure how to use it. I just copied the first 4 lines at 32 bytes each.
I will upload the file to a server.
this uses the bass library when the format is not recognised by MB:
unzip into the folder MB is installed
Leroy Bad
I installed the new patch, but it has no effect.
Here is one of the 24bit music files in question .
https://www.mediafire.com/?3ruob42q4qp6z8b
Leroy Bad
OK, now that did it.
Now it is showing everything. :)
So is this patch not apart of the full download?
