Author Topic: The easiest and most globally helpful way to also help me.  (Read 1017 times)
zBeeble
So... I've been doing some thinking about the track scanning problem.  The dozen or so tracks in that directory aren't the only ones not scanned... but I'm thinking that figuring out a list of tracks not scanned will vastly help.
To that end: a database dump (possibly in XML format, or whatever you like) would be most useful to a lot of people and most helpful to me.  I read that you have a dump to itunes somewhere --- and I can't find where that file ends up.  It says the caveat is that multiple tag values are not supported.  I would like, say, a similar XML dump with all tags included.  This would allow me to compare my list of files with the ones that the library has ingested and find the culprits.
You are not reporting a bug with your post. Therefore I have moved it to the Wishlist sub-forum.
Check out the MusicBee Wiki.
