Author Topic: [solved]switch from music bee 2.5 to music bee 3  (Read 1485 times)
whismerhill
hi,
so I read the update notes for switching from 2.5 to 3 http://getmusicbee.com/forum/index.php?topic=17326.0
I was wondering if you can install both of them on the same machine without problems ?
reason  I want to try out music bee 3 to see if I can set it up like my custom configuration of music bee 2.5
then I'll uninstall music bee 2.5 if I'm satisfied, otherwise I'll uninstall music bee 3
Is it possible ? can there be any problem with the database with such a configuration ?
Thanks.
Last Edit: September 08, 2016, 03:52:19 PM by whismerhill
whismerhill
ok from this thread : http://getmusicbee.com/forum/index.php?topic=18972.0
I read that apparently settings are stored in different locations so it shouldn't pose any problem to upgrade/downgrade
You should be okay if you still have the 2.5 installer.  But you can always install 3.0 portable to test it, and then install the regular version if you're happy with it.
