Author Topic: Can't access Artwork View after updating to MusicBee 3  (Read 1578 times)
freemann
This maybe a silly question but I can't access artwork view since updating  to musicbee 3 (may I messed up) but there is no button in the albums panel (I remember there was a button on the right side of the panel before) and I find no Artwork view option using the menu at the top left of the main panel.
Any help would be appreciated.
Thanks in advance :)
Have you tried album covers or artists view?  Depending on your configuration before, one of those will be what you want.
freemann
I only have one option cover left side and album info etc on right side. I can sort any way I want this view. But no option for other view.
Last Edit: July 01, 2016, 09:10:01 PM by freemann
You mentioned the menu at the top left.  That's where you can change which view you're using.  But make sure it's the menu for the main panel and not the thumbnail browser or some other panel.  Each panel has a top left menu.
If you're still not finding it, can you post a screenshot?
Left or right click over "Albums and Tracks" (upper left in your screenshot) and select "Album Covers"
freemann
OK that was it perfect. I didn't realize this was a menu. Accessing the menu was different before.
Thank you :)
Thanks for the feedback. Glad to hear you got it worked out.
