Author Topic: tags error  (Read 1124 times)
JoePl
Hi there,
i had an issue with the library not working decently,
now i have an issue, with the tags not being read correctly. they have been modified with mp3tag,
any chance you can link mp3tag inside the program? for convenient tag editing?
these tags were modified before the music bee installation, so long time ago. why can't it read them correctly.
http://www.mediafire.com/view/4w8hycg4hgfffaj/Bild_3.png
Hi JoePl,
Your screenshot doesn't show a difference between mp3tag and MusicBee. It only compares MS Explorer and MB.
Also I fail to see the 'bug' you believe there is.
You might want to learn about 'mapping' to see if it solves your issue. There's a lot of info about mapping on the mp3tag forum.
If you can't explain what the assumed 'bug' is exactly, I will move this question to 'general' before late.
JoePl
hi, sorry for the late replay
here is a screenshot from mp3tag. i do not see how that can help you more. it is essential the same information as in WEX. how to make it work in music bee?
http://www.mediafire.com/view/oy1ouaau2xx0xxn/Bild_1qq.png
thanks alot
can you PM me a link to a ZIP of one or two of the problem files so i can have a look at what is going on.
