Author Topic: No one answering for 2 weeks can't use MB  (Read 1111 times)
movebetter
Please Help. see "can't drag and drop tracks in playlist"
as i already said, its probably because your playlist is not sorted in natural order. Right click on the column headers/ Sort by/ Playlist order
If you still think there is an issue, post a screenshot so people can see the entire MB application and dont post a .doc file because not everyone has MS Office
movebetter
thanks Steven for your reply yes i tried that.
https://www.dropbox.com/s/j7srsdgndrehsbl/MB%20sort%20by.doc?dl=0
please see my reply to psychoadept below
Re: How to un-check Sort Ascending in Sort By
« Reply #2 on: Today at 08:14:15 AM »
Reply with quote  Modify message  Remove message
thanks for your response. i do have . "playlist order"  checked.  I have been trying to find out why i can't drag and drop tracks in playlist so i looked on my other computer  which it works fine for differences. that one has no check marks except for the "playlist order" . so i thought that might be the cause.  My other computer is going back so i will be left with the one with the problem so i am desperate because
 i make playlists for a dance and have to have the re-order option. i am looking into other players if no one can help which is a big hassle to learn and i really have liked MB.
