Every time I restart my computer this message appears:http://i.imgur.com/pFEKeMC.png
I lose my queue, skins I had selected immediately turn off and it goes to default skin, and libraries get reset to a random point in the past.
I think this might be because I don't always make sure to close musicbee before turning off my pc, but I get this error too when I do exit it properly.
I hope this can get solved, so I can start using musicbee to it's max potential. Even with this problem musicbee is still the best musicplayer there is for local files.
I won't be awake for much longer so my respones might be a bit late
